Date/Time: Sun, 28 Apr 2024 20:29:45 +0000
[User Discussion] - Macd BB Indicator
View Count: 3606
[2017-09-29 21:52:44] |
Sawtooth - Posts: 3980 |
Here's the link to the old support board: http://www.sierrachart.com/supportboard/forumdisplay.php?f=94 I think you'll find it there. |
[2017-09-30 08:07:37] |
We will add this as a built-in study.
[2017-10-01 19:20:23] |
fittjsb - Posts: 8 |
When will you be adding the MacdBB as a built-in study?
[2017-10-01 20:38:21] |
As soon as we know what the formula is.
[2018-03-11 16:12:36] |
Hi - Have you guys had any luck with adding the MacdBB as a built in study? Thanks, Jeff |
[2018-03-11 19:33:05] |
No. And we are not going to do this because we do not have the formula.
[2018-03-12 12:05:14] |
Xfanman1 - Posts: 320 |
This study exists in the User Contributed Studies so the formula should be available there I'd think. jdtMACD/BollingerBands/Heiken-Ashi Scott |
MACD_BB_Study.PNG / V - Attached On 2018-03-12 12:04:35 UTC - Size: 25.27 KB - 689 views MACD_BB.PNG / V - Attached On 2018-03-12 12:04:46 UTC - Size: 16.62 KB - 517 views |
[2018-03-12 13:47:21] |
Thank You Scott! :) I wander why Sierra Chart won't add it to the Study's since a User contributed the code?? |
[2018-03-12 14:13:43] |
Not sure. Perhaps they didn't realize it was there since the name is a little confusing. Apparently the user that wrote it used the Heiken-Ashi code to color the dots which kind of threw me off at first too.
[2018-03-12 14:17:59] |
Ya probably... I will have to test it out to see how it compares to Ninja Traders version, thanks again!
[2018-03-12 18:14:41] |
The problem is we have no definitive independent reference. But we will look at that code.
[2018-03-12 18:45:36] |
Here is the code for the NT7 version of the indicator. I'm also attaching an "improved" version for NT7 available elsewhere if it helps. This includes the standard code for the indicator. I have no idea if their "Improved" version truly is. Scott |
Private File Improved MacdBB.txt - Attached On 2018-03-12 18:44:34 UTC - Size: 1.53 KB - 700 views |
[2019-02-14 13:31:26] |
User376477 - Posts: 3 |
hello how can i get this indicator jdtMACD/BollingerBands/Heiken-Ashi i did not find it in the studies. thanks |
[2019-02-20 23:53:26] |
You need to use the Add Custom Study button then select the User Contributed Studies and you'll find the study you're looking for as I've highlighted below. -- Scott |
