Date/Time: Sat, 18 May 2024 11:02:04 +0000
referencing the value of a study on entry
View Count: 877
[2017-09-29 14:37:08] |
User606491 - Posts: 164 |
I want to reference the value of a study upon entry. How do I go about doing that? For example: the value of the upper bolinger band upon entry. thank you, Eric |
[2017-09-29 18:00:24] |
We do not understand this. Reference the study from where?
[2017-09-29 18:39:04] |
Apologies, I should have been more clear: I want to be able to use the value of a study at entry as part of my formula for exit. for example: Exit formula if price @ entry > Upper Bolinger @ entry then exit at X if price @ entry < Upper Bolinger @ entry then exit at Y I can reference price at entry from column J, but how do I reference the value of the upper bolinger band at entry? thank you |
[2017-09-29 18:59:17] |
OK we understand. This is going to be involved and is outside the scope of our support. Basically you would have to get the time of the order entry, and then reference the study value at that time in the Sheet using the date-times in column A. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-09-29 19:00:59
