Date/Time: Sat, 04 May 2024 16:35:14 +0000
Stronger Emphasis for Main Price Graph Subgraph Titles on Region Data Line
View Count: 1532
[2013-09-07 22:01:38] |
One thing we have wanted to do for some time is to put greater emphasis on the short titles for the main price graph subgraphs on the Region Data Line at the top of the chart. For example when you want to see what the High or Low for the last bar is or the current Bid/Ask is, and read the information from the Region Data Line at the top of the chart, it takes a little time to locate those values among multiple values. It would be helpful if the short titles like "H:" are greater emphasized. In this image, are a couple of examples of how we have done that through the use of underlining: http://www.sierrachart.com/image.php?l=1378591522588.png Feedback is appreciated. We can make this an option if it is an annoyance for some users. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2013-09-07 22:05:33
[2013-09-08 01:40:01] |
ejtrader - Posts: 688 |
Good idea. Wondering if you can even eliminate ":" in "H:" - which should save few more characters overall. Also - For volume numbers or any other places where applicable - if you can provide an option to display "k" or so instead of displaying all the digits that should save few characters as well. Thanks |
[2013-09-08 02:50:49] |
M5amhan - Posts: 468 |
or adding commas to the volume.. that would be great
[2013-09-08 04:54:44] |
Sawtooth - Posts: 3993 |
In region 1, I'd like to see the OHLCVT values, and study subgraph values, in the Region Data line at the crosshair location. You would then be able to remove the Status Bar, something you wanted to do in the past. In regions other than 1, the Region Data line can currently display only the value of subgraphs at the chart's far right edge. I'd like to see in the Region Data line the value of each study subgraph at the crosshair location. |
[2013-09-09 23:06:19] |
Thank you for the feedback. We have fully implemented feature and taken some of the suggestions.
