Date/Time: Sat, 18 May 2024 12:40:05 +0000
DOM SETTING
View Count: 879
[2017-09-29 09:51:22] |
User312853 - Posts: 1 |
My Sierra chart is a through GQG. I'm trying to set my DOM as attached picture (DOM), but I can not. Can you help me to set it in the same way. |
[2017-09-29 12:09:01] |
Xfanman1 - Posts: 320 |
Are you talking about setting the colors the same? If so you can do that via the Menu/Chart/Graphic Settings Chart then use the Trade DOM settings to set your colors (make sure you click the Enable checkbox if that's a component you want displayed).
DOM Color settings.PNG / V - Attached On 2017-09-29 12:08:02 UTC - Size: 99.89 KB - 274 views |
[2017-09-29 17:10:28] |
Refer to this section to customize the columns: http://www.sierrachart.com/index.php?page=doc/GlobalTradeSettings.html#CustomizeChartTradeDOMColumns Refer to this page to customize the colors: http://www.sierrachart.com/index.php?page=doc/ChartTradingCustomizingGraphics.php Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-09-29 17:10:39
