Date/Time: Sat, 18 May 2024 18:04:36 +0000
attached orders
View Count: 1104
[2017-09-28 21:03:02] |
User807026 - Posts: 86 |
I am setting up a new bracket order. I set target 1 to 1 contract at 10 ticks, target to to 2 to 1 contract at 15 ticks. I then set a stop at 2 contracts at 10 ticks. But when I set the stop to 2 contracts target 1 moves to 2 contracts. If I move the stop to 1 contact target 1 moves back to 1 contract. What am I doing wrong? I have the attached orders section several times and I see no mention of this behavior.
[2017-09-28 23:03:14] |
Here is the relevant documentation: http://www.sierrachart.com/index.php?page=doc/AttachedOrders.html#GroupQuantity For the stop order make sure you set the OCO Group setting to All OCO Groups. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-09-29 11:40:52] |
I did that but the it shows red above that says Qty: Target/stops No match.
[2017-09-29 17:27:54] |
Make sure the main parent order quantity matches the sum of the Target order quantities. You can set the Quantity on the first tab of the Trade Window: http://www.sierrachart.com/index.php?page=doc/TradeWindow.html#Quantity Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
