Date/Time: Thu, 02 May 2024 06:49:03 +0000
Updating historical data file from live feed
View Count: 1275
[2013-09-06 20:49:03] |
User93318 - Posts: 6 |
I am using 2 copies of SC per the documentation instructions. I can see the Source chart and the Destination chart for the same instrument in my Destination copy. But the Source chart is not updating from my Open Ecry real-time data feed, even though I have entered the correct symbol in the Alternate Real-Time Update Symbol field. From the documentation: 9.In the Destination copy, to be able to have a Historical Daily chart update in real time, access Market Depth data, access Time and Sales data, and/or to support trading for the symbol, enter the corresponding symbol in the Chart >> Chart Settings >> Alternate Real-Time Update Symbol
Is this a known issue? Or is there something I may have missed? Do you need to review my log or my chartbook? |
[2013-09-07 02:31:15] |
We are not completely clear as to your configuration. However, we recommend enabling Global Settings >> General Settings >> Use Non-Chart Data from Remote Instances.
