Date/Time: Sat, 18 May 2024 12:27:04 +0000
Replay function not working
View Count: 1247
[2017-09-25 04:05:36] |
User1990 - Posts: 48 |
Replay function is acting up weirdly with only blank charts with no candles showing and price ticks all over the place (not consistent across charts). Started noticing this problem today. The last time the function was used successfully was on Friday 22nd, which was two days ago. Please let me know if it's a problem on my end or there is a bug to the program on the back end. Thanks a lot.
[2017-09-25 05:03:09] |
Follow the instructions here to replay a chart: Replaying Charts: Basic Chart Replay Instructions Replaying a chart simply replays the data that is already visible within the chart. It is that simple. or there is a bug to the program on the back end. No, this is not possible. Replay only functions on the user client side.
