Date/Time: Sun, 05 May 2024 14:33:45 +0000
Problem with NumbersBar
View Count: 744
[2017-09-24 04:28:50] |
nicktrader - Posts: 665 |
I am running NB BUND without any problem but if I change the symbol to FDax I do not get a correct chart. I do not use any volume filter or similiar |
NB BUND.png / V - Attached On 2017-09-24 04:22:32 UTC - Size: 44.06 KB - 275 views NB FDax.png / V - Attached On 2017-09-24 04:26:27 UTC - Size: 18.01 KB - 284 views |
[2017-09-24 05:52:30] |
It is hard to say without getting the Chartbook, what the issue is. We want you to open a new chart for the FDAX and then add the Numbers Bars study to that chart and see if you have an issue. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-09-24 05:52:47
