Date/Time: Sat, 04 May 2024 17:03:44 +0000
bollinger bands study apply on difference (single line)
View Count: 896
[2017-09-23 08:19:40] |
User37954 - Posts: 23 |
Hi I need help. I made a spread chart, in region 1 is main graph 1, on the backround is second main graph 2 and this graph is pictured in region 2, in the region 3 on main graph is study difference line (last value graph 1 - last value graph 2). I need put studie bollinger bands on studie difference line in region 3. Is it possible apply one studie on the another studie? And if answer is yes, how can i do that. Thanks for your help. |
Capture.PNG / V - Attached On 2017-09-23 08:19:14 UTC - Size: 76.54 KB - 314 views |
[2017-09-25 17:32:04] |
Follow the instructions here to base a study on another study: http://www.sierrachart.com/index.php?page=doc/ChartStudies.html#BasedOn Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
