Date/Time: Sun, 05 May 2024 20:29:36 +0000
Stopped out NVDA what happened
View Count: 900
[2017-09-22 15:13:28] |
User49582 - Posts: 9 |
Hello Support: I was trading NVDA using IB data and this has not happened before but has happened twice today. please see the attached file. thanks http://www.sierrachart.com/image.php?Image=1506093114858.png |
[2017-09-23 07:07:08] |
You need to contact Interactive Brokers about this. We see you are also running an older version of Sierra Chart. That is not going to be relevant to the problem but you should update following the instructions here: Software Download: Fast Update Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
