Date/Time: Sat, 18 May 2024 06:02:07 +0000
Colour Alert Bar and Volume Profile
View Count: 769
[2017-09-22 11:02:26] |
User169391 - Posts: 55 |
HI, I use the Volume by price study with a setting of 4 hours(240 minutes) intervals for the volume by graph period type. I would like to add a colour alert bar that tells me if the current price has exceeded or receded below the level of the previous 4 hour interval(In affect has the current price broken above or below the previous high or low of the previous 4 hour period and if so colour the background). hope i have explained myself well enough. Please notify if not. thanks. |
[2017-09-22 17:46:30] |
To do this requires that you use this study: Previous/Period OHLC-Variable Period And write a formula using that study data. Refer to: Color Bar Based on Alert Condition Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-09-22 17:46:52
