Date/Time: Sun, 05 May 2024 12:05:28 +0000
Chart scaling help
View Count: 1317
[2013-09-06 01:45:55] |
User87197 - Posts: 65 |
Hiya! I'm having a little scaling trouble: When I double click the y-axis values scale to re-center charts I've noticed that they always try to fit all the chart drawings in as well, which can end up scrunching up the price to fit in a much larger y-axis range. How can I set it so that the autofit is only stretching to fit the main price graph into the chart (regardless of whether chart drawings are being cut off)? I'm sure it's a simple one but I can't work it out, thanks very much in advance! :) |
[2013-09-06 12:47:15] |
Sawtooth - Posts: 3993 |
Go to each region 1 study as set the Scale to Same As Region.
[2013-09-06 13:37:56] |
Thank you so much! I've wanted to do that for so long :)
