Date/Time: Sun, 19 May 2024 17:52:16 +0000
Dom columns General Purpose 1 & 2
View Count: 2736
[2017-09-11 23:56:19] |
onnb - Posts: 661 |
Global Trade Settings Windows: General Purpose 1 / General Purpose 2 The docs mention that these might be used with GDI to draw. Do you have an approach in mind on how to get window coordinates for some cell at some price level? Would you be providing some api like the window handle to each cell? |
[2017-09-12 20:34:20] |
There is only a single window handle to the entire chart window. There are no handles to individual cells. There is no way the Windows operating system could handle that and it is inefficient anyway. You will need to use this function: sc.RegionValueToYPixelCoordinate() You can use these variables to get the left and right coordinates of the Values Scale: ACSIL Interface Members - Variables and Arrays: sc.RightValuesScaleLeftCoordinate But probably you would need the exact coordinates of those columns and we can see about adding variables for those. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-09-20 22:59:29] |
onnb - Posts: 661 |
Can you create an api that returns the coordinates of any column or the coordinate of any cell? Something like this: GetDomCellCoordinates(Column, Price, Coordinates) and/or GetDomColumnCoordinates(Column, Price, Coordinates) Anything similar to that in nature where we could know the location and boundaries of any cell would be great. |
[2017-09-21 05:08:13] |
You can figure this out once we add the left and right x/horizontal coordinates of these additional columns. And by using the function linked to in post #2 above.
[2017-09-21 05:25:52] |
onnb - Posts: 661 |
True We are looking to draw with the gdi on other columns too so if you can add an api to retrieve left/right coordinates for any column that would be helpful |
[2017-09-21 05:37:46] |
OK we will make a note of that.
[2017-09-21 18:08:26] |
onnb - Posts: 661 |
Do you have an ETA or target build # for this?
[2017-09-21 18:19:10] |
No. But we would expect it to be within 90 days.
[2017-10-02 02:19:47] |
onnb - Posts: 661 |
hi - just checking in to see if you have an update on this? (Looking for a more concrete ETA if possible) |
[2017-10-02 17:09:04] |
It is not possible for us to give any estimated time unless it is urgent and then we just have to just work on it and get it done in the next couple of days. Let us know how urgent this is. Otherwise, it could go on for months. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-10-02 17:09:26
[2017-10-02 19:11:49] |
onnb - Posts: 661 |
Ok, before answering the urgency, have another question In the dom chart, I can add "Current Traded Ask Volume" and "Current Traded Bid Volume" Is there an api to access those? |
[2017-10-03 04:17:11] |
No, but we can add that in the next 2 to 3 days. We will do that. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-10-03 04:42:16] |
onnb - Posts: 661 |
Very cool Circling back to original requirement - yes it is a bit urgent, we will start using it the moment its out. I think you understand what we need but repeating it here We need some api to receive the bounds of a cell for any visible column/price level so that we can draw in it using gdi. |
[2017-10-03 09:27:20] |
We should have all of this out by the end of the day today.
[2017-10-04 01:25:52] |
onnb - Posts: 661 |
What build is this going to be in? Can you add a few words on the new api? |
[2017-10-04 04:52:40] |
It is in version 1620. These are the new functions: // 1619 int (SCDLLCALL* GetDOMColumnLeftCoordinate)(n_ACSIL::DOMColumnTypeEnum DOMColumn); int (SCDLLCALL* GetDOMColumnRightCoordinate)(n_ACSIL::DOMColumnTypeEnum DOMColumn); // 1620 uint32_t (SCDLLCALL* GetCurrentTradedBidVolumeAtPrice)(float Price); uint32_t (SCDLLCALL* GetCurrentTradedAskVolumeAtPrice)(float Price); Documentation will come as soon as possible. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-10-05 17:33:35] |
onnb - Posts: 661 |
Just reporting back works great
