Date/Time: Thu, 16 May 2024 14:40:45 +0000
Numbers Bar
View Count: 695
[2017-09-09 21:13:02] |
User123235 - Posts: 46 |
Hello, The bid/ask data is showing zero since 8/28/17. Before 8/28/17 working ok. Thanks |
Bid Ask Issue.PNG / V - Attached On 2017-09-09 21:09:09 UTC - Size: 76.91 KB - 220 views Attachment Deleted. |
[2017-09-09 23:01:52] |
Follow the instructions here to update the Symbol Settings: Global Symbol Settings: Update Symbol Settings Make sure Global Settings >> Data/Trade Service Settings >> Service is set to SC Data-All Services. Right-click on the chart before those zero values and select Delete and Download Data. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-09-09 23:02:21
