Date/Time: Thu, 16 May 2024 05:49:07 +0000
No trades coming up when I use the trade activity log. Unless it says UNMATCHED FILL
View Count: 644
[2017-09-09 01:24:33] |
dc2uh - Posts: 25 |
I am trying to import my trade activity into an online journal and nothing is coming up when i click on trade activity log, then the date, then apply. And if something does pop up it almost always says "Unmatched fill" please help! |
[2017-09-09 22:13:44] |
After you import order fills into the Trade activity Log, go to the first tab, Trade Activity, and verify that the order fills are there and all the fields are correct. If there is a problem with importing them, then there must be something wrong with the data you are importing. Here are the instructions to use the Trade Activity Log: Trade Activity Log: Viewing Historical Trade Activity In regards to unmatched fills, refer to: https://www.sierrachart.com/index.php?page=doc/TradeActivityLog.php#TradesTabUnmatchedFill Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-09-09 22:14:59
