Date/Time: Wed, 15 May 2024 02:26:34 +0000
Trade Window
View Count: 929
[2017-09-08 18:12:46] |
User806639 - Posts: 32 |
How do I activate the Flatten, Reverse, and Cancel All buttons on the Trade Window
[2017-09-08 18:46:51] |
They should be enabled unless you disabled them through Global Settings >> Chart Trade Settings. Although Cancel All is enabled if there are orders which can be canceled. Make sure you are looking at the correct Trade Window: Basic Trading and the Trade Window: Opening Trade Window for Chart or Trade DOM And that it is set to the correct Trade Account: Basic Trading and the Trade Window: Main/C >> Trade Account (Selecting Trade Account for Chart / Trade DOM) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-09-08 18:47:59
[2017-09-09 02:11:49] |
Got it Thank You |
