Date/Time: Thu, 16 May 2024 19:45:24 +0000
LastFullCalculationTimeInMicroseconds
View Count: 571
[2017-09-08 14:14:23] |
jizzary - Posts: 177 |
Hi Since it is undocumented (though there is an entry in the documentation) I would like to ask whether this info refers to the previois call of the study. Meaning - in cycle #N the API will report the data of cycle #(N-1) is that correct ? Date Time Of Last Edit: 2017-09-08 17:32:01
[2017-09-08 19:23:12] |
This indicates the calculation time the last time the study was fully recalculated. It does not indicate the time of an update calculation. An example of a full recalculation is when study settings are modified through Analysis >> Studies. When the OK or Apply buttons are pressed, all studies will be fully recalculated. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-09-08 19:23:37
