Date/Time: Sat, 27 Apr 2024 02:45:25 +0000
tick chart
View Count: 3123
[2013-09-05 11:46:34] |
michael baksheev - Posts: 27 |
how to make a intraday chart just in a tick format so u can change the no. oof ticks eg 89 tick chart 150 tick chart
[2013-09-05 11:57:52] |
ganz - Posts: 1048 |
michael baksheev http://www.sierrachart.com/index.php?l=doc/doc_ChartSettings.html#NumberofTicks |
[2013-09-05 12:43:45] |
ive only got rangeper bar standard tick and when i pull it up it doesnt look nothing like my tick charts like tradestation what am i doing wrong |
[2013-09-05 13:18:01] |
michael baksheev use Number of Trades Per Bar |
[2013-09-05 13:26:20] |
Thank you :)
[2013-09-05 16:11:16] |
You need to use Chart >> Chart Settings >> Bar Period Type >> Number of Trades per Bar: http://www.sierrachart.com/index.php?l=doc/doc_ChartSettings.html#NumberofTicks Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
