Date/Time: Thu, 16 May 2024 02:01:44 +0000
Unhandled Win32 Exception in SierraChart.exe [1956]
View Count: 1189
[2017-09-05 07:22:30] |
CarlRostron - Posts: 80 |
Very rare for me to get anything like this. My configuration in SC hasn't changed... I have attached a couple of screenshots. When Visual Studio popped up it referred to the "Microsoft Symbol Servers" and to "-Change existing PDB and binary search paths and retry:" If you want me to try anything further just advise, I'm happy to help. I was forced to exit SC by Windows. On reopening SC the problem went away. But thought I would raise this issue to you just in case you get other similar reports and you know where a problem may have been lurking. Only that I did have a symbols download issue in my most recent post which I resolved by doing a Global Symbol refresh. This sounded like a similar issue? My last Windows (10 Pro) update was on Wed 9th Aug and have used SC everyday since then so don't think a Windows issue but I'm probably wrong :-) |
[2017-09-05 19:14:36] |
We really need to be able to reproduce this. So if you encounter it again we would have to get the Chartbook you are using and the steps to reproduce.
