Date/Time: Sun, 04 Oct 2026 11:11:49 +0000
Limitations on Chart Replay - Restricted to ~30 days prior to current date.
View Count: 1631
| [2017-08-29 16:08:15] |
| User803309 - Posts: 1 |
Hello, I am in the process of evaluating Sierra Chart for my trading purposes and have the level 3 license. I'm trying to test a simple ACSIL trade-system strategy using the replay chart feature. I have set my data download preferences to download >186 days of intra-day data at minute resolution and for certain securities the download works. I'm assuming that when the download does not work, that is merely an indication of a data-restriction on my account. Not problem there. Though I'd also like to talk to sales about how I can possibly lift those restrictions. I digress... The issue I have relates specifically to when the download succeeds. When I go to replay the chart, it begins the replay on July 31st 2017 regardless of when I set the start date, and regardless of how much data I have downloaded into the chart (this was on august 28th). Is this a backtesting restriction or a configuration issue? I need more than 30 days of backtesting for this software to be a viable platform for me. Ideally, I'd like to be able to select two dates (date 1 and date 2) from more or less any time within the past 10-12 years, and replay the chart between them. I have extensivly looked in numerous places to try and see if anyone else was having the same issue without success. Thanks |
| [2017-08-29 19:26:49] |
There are no limitations. You just need to follow through the instructions here: Historical Intraday Data (Missing Data / Download Errors / Viewing More Data): Downloading/Viewing More Historical Intraday Data Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
