Date/Time: Sat, 18 May 2024 17:30:15 +0000
Naked POC
View Count: 3309
[2017-08-28 05:19:20] |
nicktrader - Posts: 665 |
In the attached pic you can see all naked POC, but unfortunately the name labels are also displayed for all visible POCs. Is that correct? Release: 1602 Date Time Of Last Edit: 2017-08-28 05:20:34
Naked POC.png / V - Attached On 2017-08-28 05:15:36 UTC - Size: 89.93 KB - 777 views |
[2017-08-29 01:33:33] |
We understand the issue. We will implement a solution to this.
[2018-09-04 10:31:11] |
Ingo - Posts: 2 |
I would like to know, what indicator are you using to show the naked poc in the volume profile. I could not find it. (I donĀ“t want to use TPO-Chart, I know the TPO-Naked but I want to use the naked from the Volume-Profile, like in the picture above) Thanks for answering, Ingo |
[2018-09-04 14:43:12] |
@Ingo Take a look in the pic. |
Settings for naked POC.png / V - Attached On 2018-09-04 14:41:56 UTC - Size: 12.64 KB - 599 views |
[2018-09-05 18:56:44] |
apollofl - Posts: 95 |
Anything on Naked POC's yet! See Post 1 Date Time Of Last Edit: 2018-09-06 00:31:27
[2018-09-05 19:06:07] |
We do not understand the question.
[2018-09-06 11:22:31] |
Until future Intersection POC's. are being Intercepted, and they are still showing up as Naked POC on the Value Label
[2018-09-06 23:36:15] |
Provide a chart image showing this so we can understand what you are referring to. Here are instructions: https://www.sierrachart.com/index.php?page=PostingInformation.php#Image Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-09-08 11:56:16] |
User508140 - Posts: 9 |
As requested....Using Numberbars with Highlight Point Of Control with column 1 with extension line until future intersection. the POC's that were intersected are still showing on the Name and Value labels http://www.sierrachart.com/image.php?Image=1536407445880.png http://www.sierrachart.com/image.php?Image=1536408139492.png Date Time Of Last Edit: 2018-09-08 12:24:20
[2018-09-09 01:29:43] |
Okay we understand what you are asking about here. We can solve this.
[2019-11-02 19:00:48] |
User718663 - Posts: 39 |
hi, is there a naked vpoc for volume profile? i know there is one for tpo but wheres one for volume profile? |
