Date/Time: Sat, 11 May 2024 21:22:44 +0000
Relcalculation Question.
View Count: 621
[2017-08-24 23:14:15] |
User549578 - Posts: 5 |
I need help please. I have exhausted myself trying to figure this out. Its simple but not getting the effect I need, without hitting the recalculate function. I created a study using the Study Price Overlay from the source chart. I am using that value say (x) then adding it so say (y) using the Study Add Subgraphs Study in the destination chart and displaying that value above the price bar in the destination chart. The study works well but only for the current bar. How do I get the study I created (Study Add Subgraphs) to automatically update the prior bars without me needing to hit the recalculate??? Please advise. |
[2017-08-25 02:58:56] |
In the latest versions of Sierra Chart this is designed to work without any problem. So if it is not, there must be something unusual you are doing or there is a problem we need to look into. We would need to get a test Chartbook from you demonstrating this. It needs to be a simple set up though. Here are the instructions to attach it: https://www.sierrachart.com/index.php?page=PostingInformation.php#AttachFile Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
