Date/Time: Sun, 12 May 2024 21:32:40 +0000
ES charts move very-very slow.
View Count: 620
[2017-08-24 19:57:58] |
User565382 - Posts: 6 |
ES charts move but very-very slow. Where should I check my setting and what numbers should I put in? I have had your charts for a long time with Windows 7. A few weeks ago I download Windows 8.1. So, I can draw charts but they move very slow with a big interval. Looks like I put wrong settings in Data/Trade Service Service Setting or Global Setting? How can I fix it? I download your soft before and without problem. But with Windows 8.1 - problem. Thank you.
[2017-08-24 23:31:37] |
You are not using the Sierra Chart Exchange Data Feed and you do not have Sierra Chart connected to a Trading service that provides real-time futures data. So at most the chart would update every 20 minutes. Would every 20 minutes be OK? If you require real-time futures data, then refer to: https://www.sierrachart.com/index.php?page=doc/doc_FuturesData.php Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-08-24 23:32:49
