Date/Time: Sun, 12 May 2024 04:36:09 +0000
send order latency
View Count: 1022
[2017-08-24 12:30:35] |
OBD S - Posts: 5 |
Hello, I use Interactive Brokers Gateway as connection to the broker. If an order is sent form Sierra Chart to IB Gateway the order has more than 1 second latency. Is that possible? Or can I make something to reduce it? Thank you Petr Klepetko |
[2017-08-24 13:49:22] |
The only thing we can say is that when you submit an order from Sierra Chart it is immediately transmitted to the connected trading service without delay. So if there is any delay, you will need to ask IB about this. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
