Date/Time: Sun, 28 Apr 2024 09:04:30 +0000
Need Ratio in Number bars calculated values
View Count: 3174
[2017-08-17 13:15:40] |
traderacademie - Posts: 38 |
Hi, I need a ratio of 2 numbers derived from the number bars studies for 2 cases (up bar or down bar). When it's an up bar: second lowest bid/lowest bid When it's a down bar: second highest offer/highest offer In case the divisor is 0, just use 1. Is this possible to do? Rgds Will |
[2017-08-17 13:37:15] |
binaryduke - Posts: 360 |
http://www.emojitrading.com/bar-ratio/
[2017-08-17 14:55:35] |
Thanks, but I'm not interested in commercial indicators, also it's a very simple thing
[2017-08-17 18:42:03] |
What exactly do you mean by "lowest bid". Are you referring to prices or volumes?
When it's a down bar: second highest offer/highest offer In case the divisor is 0, just use 1. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-08-17 19:24:13] |
User590848 - Posts: 13 |
he means something like BVAP(LOW+TICKSIZE,0)/BVAP(LOW,0) AVAP(HIGH-TICKSIZE,0)/AVAP(HIGH,0) yes.. its simple, but not possible without programming your own study :/ unfortunately.. Alert condition gives you only True/False and spreadsheet study doesnt have acces to special functions like BVAP.. Could be really nice have some study.. where we can put some calculation formula and return result like this example. Date Time Of Last Edit: 2017-08-17 19:25:28
[2017-08-17 20:03:34] |
Hi, I am referring to the volumes. I'm not sure what User590848 means. Rgds Will |
[2017-08-18 18:28:57] |
We will add these calculations into the next release.
[2017-08-21 08:16:14] |
Thanks for implementing this! I guess it's not possible to put the decimal point?
[2017-08-21 13:12:39] |
Yes, we will add two decimal places for these percentages.
[2017-08-22 04:33:54] |
Yeah I saw the two decimal numbers in the prelease, but what I meant to ask is whether or not the decimal POINT is possible to display or not
[2017-08-22 12:54:06] |
The Value Format for individual rows of the Numbers Bars Calculated Values study are either hardcoded or dependent upon the study Value Format. We will make sure this is documented for each of them. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-08-22 13:56:13] |
For the two new percentage subgraphs we will change the number of decimal places to 0 by default.
