Date/Time: Fri, 03 May 2024 22:38:03 +0000
Unable to spreadsheet autotrade FXCM
View Count: 1607
[2013-09-03 07:53:05] |
TechTrader - Posts: 116 |
The following error appears in the Trade Service Log when the spreadsheet attempts to initiate a position in live mode. Trade Order Error - FXCM order update (Rejected). Info: 19915;DAS 19915: ZDas Exception ORA-20173: Quantity fraction size violated: 10000 . Internal Order ID: 8449. Symbol: EURAUD | 2013-09-03 17:41:01 I am using the FIX credentials supplied to me by FXCM, the data is OK and I can initiate manual orders from the chart, including attached orders. 10K lot. The autotrade appears to work in simulation mode but only shows 1 in the chart position bar. Any Clues? Thanks in advance Date Time Of Last Edit: 2013-09-03 07:53:38
[2013-09-03 08:06:16] |
This is very clear. Make sure that the order quantity from the trading spreadsheet is in increments of 10000. Refer to this cell: http://www.sierrachart.com/index.php?l=doc/doc_SystemsAlerts.php#CellJ26 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2013-09-03 08:06:36
[2013-09-03 08:15:46] |
That was it! Thanks |
