Date/Time: Sun, 05 May 2024 13:57:22 +0000
Enable Spreadsheet-Trading via ACS Toolbar button
View Count: 1528
[2013-09-03 06:37:18] |
sbsierra - Posts: 71 |
Is it possible to enable disable Spreadsheet Trading via ACS Toolbar? For example use formula "=ACS2" for J28. If ACS2 is pushed Spreadsheet trading is enable, because J28 is "TRUE", otherwise it is "FALSE". bs.trader Date Time Of Last Edit: 2013-09-03 06:38:14
[2013-09-03 17:47:22] |
You can add a ToolBar button to enable/disable Trade >> Auto Trading Enabled: https://www.sierrachart.com/index.php?l=doc/doc_GlobalSettingsMenu.html#CustomizeToolbar Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2013-09-03 17:47:57
[2013-09-06 09:53:44] |
thanks that will do it. but it would be nice to combine a cell in spreadsheet with a acs toolbar for e.g. enable/disable a specific strategy. cheers, bs.trader |
