Date/Time: Thu, 03 Jul 2025 04:05:24 +0000
[User Discussion] - Unable to use drawing tool on custom chart with Bars displayed as main price
View Count: 1780
[2013-09-03 03:50:09]
maxpi - Posts: 183
I have a study that works fine, it displays bars that are greater in duration than the underlying [1T] chart. I can apply a study to the chart and it displays the study based on the bars I build as it should. I cannot apply a drawing to the chart with the mouse though. Should that be the case? The defaults are:
if (sc.SetDefaults)
    // Set the defaults
    sc.GraphName ="ACodeThingyToTestRxCode";
    // This member indicates that this is a custom chart study.
    //  This can only be set when SetDefaults is true.
    sc.IsCustomChart       =1;
    sc.GraphRegion         =0;
    sc.DrawZeros         =0;
    sc.GraphDrawType       =GDT_CANDLESTICK;
    sc.DisplayAsMainPriceGraph  =1;
    sc.FreeDLL           =1;
    sc.AutoLoop         =0;
    sc.ValueFormat         =VALUEFORMAT_INHERITED;
    sc.StandardChartHeader     =1;
    // Subgraphs
    Open.Name ="Open";
    Open.DrawStyle =DRAWSTYLE_LINE;
    High.Name ="High";
    High.DrawStyle =DRAWSTYLE_LINE;
    Low.Name ="Low";
    Low.DrawStyle =DRAWSTYLE_LINE;
    Last.Name ="Last";
    Last.DrawStyle =DRAWSTYLE_LINE;
    return;
Edit: I did a little more checking, I can indeed draw a line, cannot draw a linear regression channel. Maybe if there is a problem it's just with that one tool...
Date Time Of Last Edit: 2013-09-03 03:56:41
[2013-09-04 02:38:20]
maxpi - Posts: 183
This code builds some 100 tick bars when applied to a 1T chart. I can draw a line on the produced bars but I cannot draw a linear regression channel.
#include "sierrachart.h"
SCDLLName("Custom Study DLL")
SCSFExport scsf_RxSubgraphBars(SCStudyInterfaceRef sc)
  SCSubgraphRef Open         =sc.Subgraph[0];
  SCSubgraphRef High         =sc.Subgraph[1];
  SCSubgraphRef Low         =sc.Subgraph[2];
  SCSubgraphRef Last         =sc.Subgraph[3];
  if (sc.SetDefaults)
    // Set the defaults
    sc.GraphName ="ForumCodeForBars";
    sc.GraphRegion         =0;
    sc.DrawZeros         =0;
    sc.FreeDLL           =1;
    sc.AutoLoop         =0;
    // Subgraphs
    Open.Name ="Open";
    High.Name ="High";
    Low.Name ="Low";
    Last.Name ="Last";
    return;
  for(int i =0; i<sc.ArraySize; i++)
    if(i % 100 ==0)
      sc.AddElements(1);
      sc.DateTimeOut[sc.OutArraySize -1] =sc.BaseDateTimeIn;
      High[sc.OutArraySize -1]      =0;
      Low[sc.OutArraySize -1]       =999999;
      Open[sc.OutArraySize -1]       =sc.Open;
      if(sc.High >High[sc.OutArraySize -1])
        High[sc.OutArraySize -1] =sc.High;
      if(sc.Low <Low[sc.OutArraySize -1])
        Low[sc.OutArraySize -1] =sc.Low;
    Last[sc.OutArraySize -1] =sc.Close;
    i++;
