Date/Time: Sun, 19 May 2024 08:28:57 +0000
sierra for 3 machines
View Count: 761
[2017-08-10 14:19:20] |
User30743 - Posts: 364 |
hi, now i have a license of siera for two laptos, when i connect a third one, it keeps telling me a mistake message that i cant login. what it takes to make it available for 3 machines? |
[2017-08-10 14:26:02] |
You can activate support for additional systems from this page: https://www.sierrachart.com/UserControlPanel.php?page=ServicesActivation Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-08-10 14:26:08
[2017-08-11 14:29:07] |
so normaly my package is for 2 laptops? and if i want one more, i will pay +8 usd each month, correct?
[2017-08-11 14:58:34] |
Yes this is correct.
[2019-11-20 13:53:21] |
tomas262 - Posts: 135 |
Hello, will the Denali feed be available to all 3 systems then too? |
[2019-11-20 14:37:52] |
No most definitely not. This is not allowed by the CME.
