Date/Time: Sun, 19 May 2024 06:52:42 +0000
tick volume per bar
View Count: 789
[2017-08-10 13:18:09] |
User807026 - Posts: 86 |
I set up a volume profile yesterday on a chart with the tick volume per bar at 1. Today I open the chart and the tick volume per bar is 5 and I can't change it back to 1.
[2017-08-10 19:28:07] |
You need to modify the Volume at Price Multiplier for the chart to 1: Chart Settings: Volume at Price Multiplier for Historical/Intraday Chart (Chart >> Chart Settings >> Chart Data >> Volume at Price menu) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
