Date/Time: Sun, 19 May 2024 10:52:26 +0000
ASX Australian stocks
View Count: 1019
[2017-08-10 03:16:55] |
User832316 - Posts: 2 |
Hi how do i get the charts for australian shares? cheers
[2017-08-10 03:26:10] |
Neo - Posts: 198 |
.AX
[2017-08-10 03:47:48] |
You need to use the Sierra Chart Historical Data Service which is documented here: Sierra Chart Historical Data Service Here is the symbol list: https://www.sierrachart.com/index.php?page=doc/SierraChart_RealTime_And_Historical_Symbols.php&SymbolsPage=Stocks&ID=1#ASX Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
