Date/Time: Mon, 29 Apr 2024 02:58:26 +0000
egianal connection error
View Count: 2130
[2013-09-02 18:15:49] |
surendersara - Posts: 2 |
I am unable to connect using your software - i have other software they connect fine - i run your program as ADMINISTRATOR file:///C:/SierraChart/Data/MessageLogAnalysis.htm |
Siera_esignal_1.PNG / V - Attached On 2013-09-02 18:14:34 UTC - Size: 89.76 KB - 514 views Siera_esignal_2.PNG / V - Attached On 2013-09-02 18:14:46 UTC - Size: 88.27 KB - 460 views Attachment Deleted. |
[2013-09-02 18:35:05] |
Connecting to eSignal... | 2013-09-02 14:24:50 Socket error on address resolution: Windows error code 11004: The requested name is valid, but no data of the requested type was found. | 2013-09-02 14:24:53 Error connecting to Data or Trading service. For help with this issue, press the Send For Analysis button on this window. | 2013-09-02 14:24:53 To prevent further connection attempts, select File >> Disconnect. | 2013-09-02 14:24:53 Disconnected from eSignal. | 2013-09-02 14:24:53 Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2013-09-02 14:24:53 |
[2013-09-02 19:28:11] |
E-Signal is still not yet supported at this time. We are waiting for E-Signal to make the service available. Refer to: http://www.sierrachart.com/index.php?l=doc/ESignal.php Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
