Date/Time: Sun, 19 May 2024 06:51:59 +0000
User Question
View Count: 887
[2017-08-09 21:18:40] |
Sierra Chart - Max - Posts: 5618 |
I haven't signed up for an account because I don't have a broker and I am at the stage of buying a laptop.
I need to know the size laptop I will need for Sierra Chart software. I plan to utilize Sierra Chart software and historic data. The laptops I am looking at are as follows: Screen: 11" RAM: 4 GB dual core Solid state Drive: 128GB Will this fulfill the needs of you software or do I need more power? Can you recommend a good Futures/Options brokerage firm that uses Sierra Chart software? Sierra Chart Support |
[2017-08-10 01:44:45] |
This laptop might be adequate, you really should have at least 8 gigabytes of memory on the laptop. Also make sure that the resolution of the screen is at least 1366 x 768. high would be better, but with 11" 1920 x 1080 might be a good upper limit. So did you want to trade both futures and futures options? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-08-10 05:50:07
