Date/Time: Thu, 02 May 2024 20:33:22 +0000
pivot points disappear on v1019
View Count: 1760
[2013-09-02 16:19:50] |
fobglobal - Posts: 51 |
Hi: I upgraded to V1019 from V1015 and now all my pivot points-daily (study) are gone. Could you tell me how to have them again? Thanks |
[2013-09-02 19:35:16] |
M5amhan - Posts: 468 |
if you have them based on a daily chart, you need to go in and reassign the chart number in the pivot points settings.. they fixed a problem with the pivots recently and for some reason it messed up the chart number assignment
[2013-09-02 19:49:49] |
Yes, check the Daily Chart # input with the Pivot Points study. We will see why that did not update properly.
