Date/Time: Sun, 19 May 2024 07:51:17 +0000
Combining three different instances of the "Bar Difference" indicator into one indicit
View Count: 1318
[2017-08-08 22:08:01] |
User71822 - Posts: 24 |
I have found that the "Bar Difference" indicator in Sierra Charts has been helpful in my trading. I use it by applying 3 different instances of the indicator ,overlaid over each other, in the same chart window. I would like to combine all 3 instances into a "Custom Indicator". This would allow me to apply all three indicators to any chart with one click, without having to create three separate instances of the indicator. Thanks for your help, Peter |
[2017-08-09 00:14:19] |
If you want, we can refer you to a programmer. Let us know.
[2017-08-09 17:50:44] |
Thanks for your response. Yes, I would appreciate it if you could refer me to a programmer. Best Peter Habig |
[2017-08-09 18:16:57] |
Contact Jim@sierrachart.com.
