Date/Time: Sun, 05 May 2024 12:04:18 +0000
TPO chart-How do I make price text and date text larger
View Count: 1841
[2013-09-02 14:13:39] |
User57124 - Posts: 48 |
On my Tpo chart i cnat find the setting to enlarge the price and date text? ugh thx in advance for reply |
[2013-09-02 19:19:15] |
Sierra Chart - Max - Posts: 5605 |
You will need to set the Chart Text Font size under Graphics Settings: https://www.sierrachart.com/index.php?l=doc/doc_GraphicsSettings.html Sierra Chart Support Date Time Of Last Edit: 2013-09-02 21:12:47
[2013-09-02 19:45:18] |
I have been trying to change in the location you said, The siz eWILL not change or the font style will not change, its like this chart is locked to a preset size and font.What do i need to do next ive had this problems for weeks, tried restarting program etc.Suggestions?
[2013-09-02 20:28:40] |
Please refer to the introduction section here: https://www.sierrachart.com/index.php?l=doc/doc_GraphicsSettings.html#Intro Also make sure to either click OK or Apply on the Graphic Settings window to set the settings. Sierra Chart Support |
[2013-09-02 21:14:13] |
In your case you probably will need to change the font through Chart >> Graphics Settings.
