Date/Time: Fri, 03 May 2024 21:33:52 +0000
Sharing data between two copies of SCH
View Count: 1454
[2013-09-02 09:04:48] |
Veronika Skrehotova - Posts: 8 |
Hello, I would like to share data between two copies of SCH. As Source copy I have Zen-Fire data and as Destination copy I have Interactive Brokers. I followed your instruction in "Using Multiple Trading Accounts at the same time" article and I stopped in number 5 of "Sharing data between installed copies" article. I have problem with filling the Instance list box at the top of the Find symbol window in the Destination copy. I am not able to change the default instance (Interactive Brokers to Zen-Fire). I attached the printscreen. Please, could you advise me how to change the default instance? Thank you, Veronika Skrehotova |
Instance list box.docx - Attached On 2013-09-02 08:59:20 UTC - Size: 57.34 KB - 479 views Attachment Deleted. |
[2013-09-02 09:33:21] |
Are you trading using your Zen-Fire account? Why would you want to share the data from Zen-Fire with Interactive Brokers? You should just be trading directly through Zen-Fire. The answer to the question can be found here: https://www.sierrachart.com/index.php?l=doc/MultipleServices.html#SharingWithAdminAccess Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2013-09-02 09:33:45
[2013-09-02 11:35:46] |
For trading I use Interactive Brokers account because they have the lowest commisions,... As datafeed I use Zen-Fire because Interactive Brokers doesn´t have tick data. I know that it is possible to have data from one broker and do trading with another broker in SCH. So I try to set the sharing data between two copies of SCH but I have problem with Instance list box - I can´t choose anything. Please, can you advise me how to change the default instance? Thank you, Veronika Skrehotova |
[2013-09-02 21:19:59] |
The documentation we linked to describes this kind of issue when some copies of Sierra Chart are running with Administrator access and some are not. Please check this again: https://www.sierrachart.com/index.php?l=doc/MultipleServices.html#SharingWithAdminAccess Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
