Date/Time: Tue, 07 May 2024 10:10:14 +0000
Warning: WorkbookSet is locked!
View Count: 3333
[2013-09-01 22:17:58] |
gkm - Posts: 15 |
After upgrading to the latest version, I get this warning on all my spreadsheets. None of my sheets are protected. The caption states: Each call to GetLock must be followed by a corresponding call to ReleaseLock.
See the SpreadsheetGear.IWorkbookSet.GetLock documentation for recommended best practices and examples. And the solution is? |
[2013-09-01 22:57:16] |
We are not sure why this is happening. We recommend restarting your computer and reopening Sierra Chart and see if you still get the error. If so, please send us one of the Spreadsheet files this error is occurring with. These are located in your Sierra Chart Data folder. The location of that folder can be determined through Global Settings >> General Settings. You can privately attach the file here by following these instructions: https://www.sierrachart.com/index.php?l=PostingInformation.php#AttachFile In the newer Spreadsheets that we are developing, this kind of problem cannot occur. The new Spreadsheets are still under development but are currently available in the non-CLR version. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2013-09-02 16:01:19] |
gkm - Posts: 15 |
I will try the restart of the computer. I had tried a SC restart. If that doesn't work, I'm just going to rollback the computer and see if I can get back to baseline. I updated to the latest non-CLR version for my home computer on the weekend. While adding a spreadsheet study/system for trading (for instance, onetradeexample) pulls in the price data and other already added indicators, it doesn't bring in any user defined formulas from the pre-built study. For example, there is no buy/sell formula. Should that not happen? |
[2013-09-02 19:51:54] |
We currently do not have any function to copy data and formulas from the old spreadsheets (which we have posted on this website) to the new spreadsheets. This will be done later on. We do not recommend rolling back the computer. It does not seem like that would help. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
