Date/Time: Fri, 03 May 2024 03:59:24 +0000
FX CME Futures producing weird bar??
View Count: 1383
[2013-09-01 22:16:01] |
user40663 - Posts: 54 |
Hi Getting a weird bar for Friday's bar on daily charts for AD#, @BP#, @CD#, @EU#, @SF# and @JY#. Example is @EU#. Not sure what is causing it? Thanks |
@EU# Daily.JPG / V - Attached On 2013-09-01 22:15:41 UTC - Size: 16.31 KB - 451 views |
[2013-09-01 22:32:17] |
This is what we see: http://www.sierrachart.com/image.php?l=1378074710534.png Try re-downloading the recent data for that symbol through the Edit menu. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2013-09-02 01:22:03] |
Tried that and getting the same issue - could you please double check your chart again? Also, I did do an IQ Feed update to 5.1.0.3 in the last couple of days, I wonder if that could be causing it? @CD# example attached. Doesn't seem to be affecting any other charts. Thanks |
