Date/Time: Sun, 19 May 2024 00:37:12 +0000
ZigZagCumVolume
View Count: 1700
[2013-08-31 11:32:42] |
Ronin - Posts: 35 |
Hi, I've been struggling a lot to add the ZigZagCumVolume study but unfortunately with no success - I'm referring to this thread - http://www.sierrachart.com/supportboard/showthread.php?t=33108&page=8 Dear support - What should I do in order to get the study to work? I understand that it wasn't developed by u but my question is not to the study itself but to explanation on how to run it (please check ur post #197 with the updated file)- basically what I need to do is to update the study by compiling it and creating a new DLL? then I will be able to run it? - I tried to create the DLL but with no success (attached image of the process) Is there any other/newer study that u know of that's related to the (ZigZagCumVolume / Weiss Wave technique) ? thanks a lot for ur help Date Time Of Last Edit: 2013-08-31 11:36:38
zigzagcum.png / V - Attached On 2013-08-31 11:32:22 UTC - Size: 136.17 KB - 451 views |
[2013-08-31 12:20:37] |
The compilation problem has been resolved in the latest prerelease. Update by selecting Help >> Download Prerelease. Additionally, you will find in Analysis >> Studies the Zigzag Cumulative Volume study. This will do what you want. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2013-08-31 21:14:27
[2013-08-31 13:19:37] |
Ronin - Posts: 35 |
great support as always, thanks!
[2013-09-06 12:08:55] |
nioko54130 - Posts: 108 |
Hello Support team, I'm using SierraChart 1014, and i can't find the Zigzag Cumulative Volume study. Is it still available ? Thank's |
[2013-09-06 18:01:07] |
You do need the latest version of Sierra Chart for this study. Please update with Help >> Download Current Version. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
