Date/Time: Fri, 03 May 2024 07:29:18 +0000
Peaks and Valleys
View Count: 1341
[2013-08-31 07:35:04] |
TradingMarketProfile - Posts: 120 |
Hello is it possible for you to add an option in numbers bars studies ? At the moment, the option is "draw peaks and valleys" yes or no, so can you do the same but separately, so one option for peaks and one for valleys Thanks |
[2013-08-31 10:57:44] |
In newer versions of Sierra Chart, the Volume by Price study supports drawing Peaks or Valleys or both. There are several choices. This is not supported with Numbers Bars and there are no plans for this. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2013-09-01 06:42:50] |
ok thanks
