Date/Time: Mon, 29 Apr 2024 18:16:36 +0000
sc.Input[].SetStudySubgraphValues()
View Count: 1284
[2017-07-23 15:25:56] |
binaryduke - Posts: 360 |
After a user has selected a Study Subgraph (or chart/study/subgraph when using sc.Input[].SetChartStudySubgraphValues), it does not seem possible for the user to set this field to an empty value. An empty value only appears possible to be set during a study's sc.SetDefaults phase using sc.Input[].SetStudySubgraphValues(0,0). Would it be possible to amend the handling of this family of drop down list inputs to enable a user to change these field back to a zero value? |
[2017-07-23 22:18:39] |
This is something we do not have any time for. It is not something we are going to prioritize. Therefore, we would not get to this until at least two years from now. We recommend using another Input to cause this Input to be ignored in your study function. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-07-23 22:19:18
[2017-07-23 22:20:38] |
You can also make a call to this outside of the sc.SetDefaults block: sc.Input[].SetStudySubgraphValues(0,0). Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-03-11 19:58:07] |
TedMar - Posts: 189 |
Any new ideas to set Value to 0?
[2019-03-13 06:52:10] |
@ackin but the value input for "SetStudySubgraphValues()" is dynamicly when u select them
