Date/Time: Tue, 07 May 2024 01:48:42 +0000
study collections
View Count: 1501
[2013-08-31 04:28:19] |
setapakforex - Posts: 10 |
can i export SC study collections to MS VS? I want to modify certain study collections source code in VS. |
[2013-08-31 10:59:10] |
Study collections can be modified directly within Sierra Chart. Once the study collection is applied to the chart, you can change the settings for any of the studies through Analysis >> Studies. If you want to modify the study source code directly, refer to this page here: http://www.sierrachart.com/index.php?l=doc/doc_BuildCustomStudiesDLL.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
