Date/Time: Thu, 16 May 2024 05:05:54 +0000
does SC data supports Bitcoin
View Count: 2368
[2017-07-23 06:41:41] |
User61576 - Posts: 418 |
and other cryptos? looking for level 1 historical data |
[2017-07-24 05:00:28] |
Refer to these pages: https://www.sierrachart.com/index.php?page=doc/Bitcoin.php BitMEX Trading Service Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-07-24 19:42:50] |
i connected to SC data and used symbol BTCUSD-BITFINEX 1. is this the correct symbol? 2. i didn't get any historical bid/ask data which is not as written on help page (Historical BidVolume and AskVolume: Yes.) i hope to get the numbers bar study work on Bitcoin same as it does on ES futures thanks |
[2017-07-25 14:32:34] |
Yes that is the correct symbol and we need to prepare documentation for how to use the Numbers Bars study with these types of symbols. It requires an adjustment to the Tick Size. We will have this done by the end of the day today. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-07-26 04:21:05] |
Refer to the documentation here: https://www.sierrachart.com/index.php?page=doc/Bitcoin.php#NumbersBarsStudyWithBitcoinCryptoCurrencySymbols Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-07-26 18:37:08] |
great! thanks! working! now I added the bitcoin volume indicator and read here https://www.sierrachart.com/index.php?page=doc/StudiesReference.php&ID=336 but i could not understand why this one is better than regular voluem one last question, is there is an aggregated symbol which has all exchanges feed? |
[2017-07-26 19:33:33] |
one more thing check please the attached screen shot where i set the btc chart to be delta chart for amount of 200 but since the trades done or tiny moves, the delta match the criteria which is causing wrong values also it takes a lot of time to load / update chart when in delta modea in min. time frame it's ok (seed) pls advice thanks |
2017-07-26_22-24-49.jpg / V - Attached On 2017-07-26 19:32:35 UTC - Size: 407.18 KB - 327 views |
[2017-07-27 03:46:00] |
i am attaching another volume question pls check the attached screenshot on the left you can see a spike in the bitcoin and the volume is indicating on 478 units while the same spike in price is shown on the right side through another data collector where you can see the volume was 340,000$ (which is ~ 136 bitcoins) so my question is again how this volume indicator is being counted thanks! |
bitcoin volume.jpg / V - Attached On 2017-07-27 03:45:38 UTC - Size: 600.54 KB - 329 views |
[2017-07-27 17:21:11] |
The only way to see the true volume for a Bitcoin/crypto currency symbol is to use the Volume-Bitcoin study. one last question, is there is an aggregated symbol which has all exchanges feed? check please the attached screen shot where i set the btc chart to be delta chart for amount of 200 but since the trades done or tiny moves, the delta match the criteria which is causing wrong values Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-07-27 17:27:29] |
In response to post #8, the Volume study shows the quantity traded for the duration of the chart bar. That is all we can say. Any other questions are outside the scope of our support. In the case of symbols which use fractional quantities, the volume that Sierra Chart will report is not 100% exact. It will be slightly less. Perhaps it is underreporting it by 1%. Certainly not overreporting it. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-07-27 17:28:09
[2017-09-10 19:41:41] |
The Delta Volume Per Bar Bar Period Type is not currently supported with Bitcoin/crypto currency symbols. It will be in the next release.
is there is an update for this issue?thanks |
[2017-09-10 21:01:45] |
This has been released.
