Date/Time: Fri, 03 May 2024 22:34:27 +0000
Question on charges for Sierra data.
View Count: 540
[2017-07-21 18:35:09] |
Robert D - Posts: 24 |
If I have sierra data and run multiple instances of sierra on the same computer will there be an additional $20 fee for each instance running. Thank you, Bob |
[2017-07-21 23:58:46] |
Yes there would be in the case of the Sierra Chart Exchange Data Feed. Although you could use this feature to share the data on the same computer: Using DTC Server for Data and Trading in Another Sierra Chart Instance Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
