Date/Time: Mon, 29 Apr 2024 05:38:06 +0000
[User Discussion] - Long entry orders are shown as short and vice versa in graph
View Count: 913
[2017-07-21 15:24:33] |
User287992 - Posts: 51 |
If I we are in short position and we have long entry order filled it is shown as short exit instead. Same can happen for oposite situation. This results in confusing results and same is shown in Trade Activity Log. It would be nice if Long orders stayed long and short remained short on graph no matter the current inverse position. Following trades: 3533.75 short entry
3533.50 short entry 3533.25 short entry 3532.25 short entry 3532.00 short entry 3531.00 short entry 3538.50 short exit 3539.50 short exit 3539.75 short exit 3540.75 short exit 3541.00 short exit 3541.00 short exit << 3541.25 long entry << 3533.50 long exit Should be: 3533.75 short entry
3533.50 short entry 3533.25 short entry 3532.25 short entry 3532.00 short entry 3531.00 short entry 3538.50 short exit 3539.50 short exit 3539.75 short exit 3540.75 short exit 3541.00 short exit 3541.00 long entry << 3541.25 short exit << 3533.50 long exit all trades have TP/SL 7.5. Version SierraChart 1580 |
Screen Mismatched Entry Exit_crop.png / V - Attached On 2017-07-21 15:18:05 UTC - Size: 55.78 KB - 253 views |
[2017-07-25 12:51:45] |
Any comment, please?
[2017-07-25 13:28:57] |
No comment. This is marked as a user discussion.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-07-25 13:29:06
[2017-07-25 14:53:04] |
How is it a user discussion when its clearly a bug?
[2017-07-26 05:44:40] |
You have got to be kidding us. Do you really believe that there is a bug here? It does not matter what your answer is. We have marked this as a user discussion and it is not something we will pay attention to. There is nothing wrong here. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
