Date/Time: Sun, 05 May 2024 11:16:45 +0000
24h rolling vwap and standard deviation lines stop drawing
View Count: 1639
[2017-07-21 14:55:22] |
User628042 - Posts: 8 |
http://www.sierrachart.com/image.php?Image=1500648512432.png I'm replaying previous days at 4x and when starting out the rolling vwap lines draw correctly. At some point the lines stop and I need to go into the vwap study, and click apply without changing anything and it will draw the lines. |
Attachment Deleted. New Bitmap Image.bmp - Attached On 2017-07-21 14:54:27 UTC - Size: 5.27 MB - 361 views |
[2017-07-21 21:53:24] |
Here are my vwap settings in case I've done something wrong....
New Bitmap Image.bmp - Attached On 2017-07-21 21:52:07 UTC - Size: 5.27 MB - 369 views |
[2017-07-21 22:20:11] |
We do see the problem and we will have this resolved in the next few days. It has something to do with using a Three Line Break chart which is an unusual set up. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-07-25 04:46:42
[2017-07-25 04:46:16] |
We should have this issue resolved by the end of the day tomorrow.
[2017-07-26 22:19:41] |
We have determined the reason for the problem and this is now resolved and we will have a new release out later this evening.
[2017-07-28 16:28:53] |
In what version is this fixed. I've tried both the pre and basic release with neither working.
[2017-07-28 16:46:48] |
Version 1590 or 1591. If you still have the problem we need to get your Chartbook and test it. Follow the instructions here: https://www.sierrachart.com/index.php?page=PostingInformation.php#AttachFile Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-07-28 18:22:27] |
Attached my chartbook. VWAP STDEV is the chart with the problem.
Private File |
[2017-07-28 22:22:54] |
This is now resolved. Update to the latest prerelease again. The version number is the same. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
