Date/Time: Sat, 27 Apr 2024 23:08:21 +0000
text column on DOM
View Count: 721
[2017-07-21 12:16:26] |
User884550 - Posts: 149 |
could not find any way to add a text column to trading DOM to mark the levels, if there really no way to do this? its not a very complicated feature i assume? can you consider adding this please? |
[2017-07-21 17:39:48] |
This is not supported. You can use the Type Text Drawing Tool on a standard chart.
