Date/Time: Thu, 09 May 2024 00:56:35 +0000
Hidden orders
View Count: 1060
[2017-07-21 12:11:55] |
User287992 - Posts: 51 |
Is it possible to mark new orders created by ACSIL as hidden (not shown in order book)? If not, can you implement such switch? Interactive brokers TWS supports manual setting for that. It should be similiar as setting order to DAY/GTC Thank you. |
[2017-07-21 13:23:08] |
No, this is not supported and will not be added.
[2017-07-21 14:27:39] |
Thanks for the reply. Can you elaborate a little bit on this one? Why? It seems perfectly ok for IB, they even said it can be preset for all orders created within TWS, but comming from 3rd party such as Sierra Chart it needs to be set withing said 3rd party. It is just a protection of certain orders in certain situations. https://www.interactivebrokers.com/en/index.php?f=596 |
[2017-07-21 16:51:32] |
The best we can do is add a global setting to cause any submitted order to TWS to be flagged as hidden. We will quickly do that. Otherwise, this is far beyond any development we can do now. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
