Date/Time: Thu, 02 May 2024 22:09:12 +0000
chart regions
View Count: 1572
[2013-08-30 16:57:06] |
User77503 - Posts: 48 |
I have a TICK chart and I would like to put a breadth chart above it, in a different region, how do I do that?
[2013-08-30 18:53:03] |
Please define what "breadth chart" means. We need to understand specifically what you are looking for.
[2013-08-30 19:07:39] |
sorry- the SP500 net advancers/decliners chart
[2013-08-30 23:32:53] |
This is available. Refer to this page for the market statistics symbols: http://www.sierrachart.com/index.php?l=doc/helpdetails66.html The symbol you probably want is: $NSHF At the bottom of that page has instructions for overlaying that chart on another chart. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
